shaikon
Voyager
Voyager
Filtering order of operations
I am filtering a Video stream of B/W images using Kernel Convolution (5x5 FIR) and a Temporal Filter (IIR averaging of frames).
Is the order of operations important ? What filter should be applied first ?
florentw
Hi @shaikon,
Try both and check the results. It is hard to tell directly. But it might be the same in both order.
Florent
Florent
