_underscore_
Fir compiler resource use
Hello everyone,
I'am currently trying to use a FIR compiler with 128 coefficients and a 80 Mhz sampling and input frequency, the configuration that I am using is as presented in the joined screenshot.
The issue that I am facing is that, this configuration requires a lot of DSPs, so I thought about increasing the clock frequency => the input sampling frequency will be 80 MHz and the clock frequency will be 320 MHz, my question is : Should the clock frequency that I give to the FIR be 320 MHz or 80 MHz ? And knowing that the data that I am giving to the FIR are clocked at 80 MHz can this configuration cause any timing issues ?
Any idea or suggestion is welcome.
Thank you.
vkanchan
Hi @_underscore_ ,
The clock frequency should be 320 MHz  to the FIR. This will help in time sharing the DSP slices and therefore reduce DSP slice utilization
