Visitor kk909
How to get P240 ADC and DAC simulink block?
I am using Virtex 4. The boad came with Memec P160 Analog module.
I had tried to configure my design into FPGA using system generator.
Now I am facing a problem.
As I know gateway in and gateway out does't configure into FPGA.
Gateway in acting as changing double values to fixed point values and vice versa for gateway out.
My input signal is sampled analog signal.
How can I convert into fixed point so that signal can be processed by FPGA? Is it  using  ADC?
And to get the output ?Is it using DAC? And How can I get P240 ADC and DAC simulink block?
Re: How to get P240 ADC and DAC simulink block?
Gateways *can* be synthesised - they turn into device pins (there's a tickbox on the properties page to control this, and IIRC you can assign pin numbers)
So you need to have a gateway in for your ADC data bus, and another pin that says when a new sample has arrived, and off you go...
Cheers,
Martin
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
Visitor groupeeseo
I have the same problem, in my case if I go to gateways properties the tickbox for DAC (or ADC) do not appear  in the window, how is it possible?
Thanks for your help
I think here is simple procedure
1. Generate the HDL for your design in sysgen.
2. Create ADC/DAC interface for your P240 module.
3. instantiate your design in P240 module
Thanks and Regards
Balkrishan
