hijo86
How to insert Black Box programmatically in a simulink model
I want to modify a simulink model by adding a Black Box of Xilinx, in which a vhdl-file should be integrated.
Adding such a block could be done by:
add_block('xbsBasic_r4/Black Box', [RootName,'/HDL_PWM4'],'Position',[400,0,600,550]);
Than a dialog box appears for the vhdl code path. This is the problem. How can i handle this dialoge box?
Is there a specific interface for Xilinx-Blocks to deal with them programmatically?
nathanx
see UG958 chapter 4 for Programmatic Access.
hijo86
Thank you very much. This is, what i looked for.
But the documentation is not realy detailled. I want to insert a black box. This works, but the configuration wizard opens. I don't know, how to automize this part. Is there a possibility to define in the source struct the VHDL file.
Can you help me?
nathanx
This is the only doc we can find on the programmable access, if you do not find a way in this doc, then we don't have a programmable way to insert a blackbox for now.
hijo86
Hallo,
is there a possibility to get informations about the xBlock.m(/.p) function with respect to the attributes for the "black box".
If I would have a list of attributes or setable characteristics, I could try to insert the black box. For example "toplevel" is a attribute, which is never documented, but possible.
