Visitor prasathec
How to program FPGA in ZCU102
I am a student from Dresden, Germany. I have certain functions (Matlab and C), which I want to implement/run a part in FPGA and some in Core of ZCU102 kit. Since I am new to this platform, I have been trying identify sources/tutorials which could help me to proceed with this. Hardest part is, Vivado tutorial base is too vast, such that I could not find what is relevant and what is not. Can someone help me with the flow (for instance with the Vivado tutorials)?
Re: How to program FPGA in ZCU102
Hi @prasathec
It will be worth referring this tutorial on SysGen with Vivado design suite:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug948-vivado-sysgen-tutorial.pdf
Rohit
Hi @prasathec
Rohit
Visitor prasathec
Hi Rohit,
I have started working on that. I will update you once I'm through!
Best,
Prasath
Visitor prasathec
Hi @thakurr,
Thanks for the information. It helped.
At the moment, I am working on UG1209 Embedded design tutorial. I have an issue, when configuring terminal in SDK. For my working environment, the connection type is 'telnet' (instead of Serial communication). Does this require configuration changes elsewhere?
I can able to connect to the terminal. Once I run the Hello-World example on hardware (Launch on Hardware - System Debugger), ARM Core 0's status is Running (in XSCT console) , but I could not see print statements in Terminal. For verification purpose, I just tried storing a random text in a file, but once the launch is initiated, I could not find yet the output file in the parent directory. I have verified that proper *.elf file is passed on during the launch. Please help me out in this regard!
Best Regards,
Prasath
