How to use XtremeDSP DSP48A slice in Core Generator for Spartan-3A DSP?
Hi All,
Why I can't use XtremeDSP Slice such as Multiply Accumulator in Core Generator (Version: 10.1.01) for Spartan-3A DSP FPGAs?
Can anyone help me, thanks.
Best Regards,
Bingo Zhang
Message Edited by bingo.zhang on 06-03-2008 10:52 PM
Are you setting it up correctly for multiply accumulate?
RJ Duran
Customer Application Engineer
Technical Support: http://www.xilinx.com/support
Xilinx User Community: http://forums.xilinx.com
RJ Duran
Hi RJ,
First, I think the installation should be correct.
And the problem is the dedicated IP Core which I need is gray (not available) in the Core Generator.
I have installed the latest IP update for ISE 10.1.
Could you please affirm this case again, thanks.
Best Regards,
Bingo Zhang
Are you talking about using the Multiply Accumulator v4.0 core in coregen 10.1.1 IP Update 1 for a Spartan 3A DSP part?
At this time the multiply accumulate core doesn't support the part. The best way is to either let the tools infer it or manually instantiate it using the instantiation template available in the libraries guide.
(http://toolbox.xilinx.com/docsan/xilinx10/books/docs/spartan3a_hdl/spartan3a_hdl.pdf)
Message Edited by rjduran on 06-05-2008 10:16 AM
RJ Duran
Hi RJ,
Thanks for your kindly support, and the problem is solved
Best Regards,
Bingo Zhang
