weixie
ISE 14.4 System Generator Matlab configurator can not connect to Matlab 2011b
Dear Experts
I have installed ISE 14.4 suit, Matlab 2013A (64bit), and Matlab 2011b (32bit).
My windows system is Win7 64bit.
Now I want to connect system generator with Matlab 2011b by system generator MATLAB configurator.
If  i find the folder of Matlab 2011b through "Find Matlab" button, there is alweays an error "The path you supplied is not a valid MATLAB path or has already been added".
When i want to remove the Matlab 2013a from system generator MATLAB configurator, the button "Remove" alweays unavailable.  Some details can be seen in the attach.
Based on this condtions, do you have some suggestions ?
Thank you for your time and i am looking forward to your support
yenigal
Check below threads
http://forums.xilinx.com/t5/Installation-and-Licensing/System-Generator-can-not-find-the-correct-MATLAB-version/td-p/188312
http://forums.xilinx.com/t5/DSP-Tools/Matlab-version-select-question/td-p/532893
Satish
yenigal
You have to select it using the tick mark to the left of R2013a to get the Remove button Highlighted.
Check below snapshot
Satish
weixie
Hi Mr. Satish
Thank you for your support
Hoever, as you sugessted, I select it, but i still can not remove the MATLAB 2013.
yenigal
Can you select ISE under the Xilinx Suite Tab and try adding the Matlab using Find Button.
Satish
weixie
HI,
I have tried what you sugessted. it still does not work. when i use the find button,  the same error happend, as shown in Fig. 3.
My key motivation is try to connect system generator to Matlab 2011b, based on this issuse, do you have some commands ?
yenigal
Check below threads
Satish
weixie
Dear Satish,
Thank you for your support. It means that the only way i can connect the system generator to Matlab 2011b (32bit) is install a windows 32bit system. I will try it and thank you again.
santhu37
I had the same issue and resolved with the help of this link. My xilinx is up with Matlab 2011a and running!!
http://www.opal-rt.com/KMP/index.php?/article/AA-00795/0/After-the-installation-of-Xilinx-installed-version-of-Matlab-is-not-detected-by-the-System-Generator.html
weixie
Thank you very much for the useful information.
