thiru_ashok
LDPC Encoder/Decoder v2.0 5G EXAMAPLE DESIGN
Processor-based example design for LDPC Encoder/Decoder v2.0 IP is not working as excepted for 5G. I am using Vivado 2019.2.1 in windows. I get the same error count before and after the decoding for almost all SNR. Other configurations (default & wifi 802.11) are working fine. 5G in Example design for soft-decision FEC (1.1) IP is also working fine. I have attached the screenshot for the simulation and the example design parameters below. Can anyone guide me on this?
nathanx
Other configurations (default & wifi 802.11) are working fine. 5G in Example design for soft-decision FEC (1.1) IP is also working fine. What's the configuration not working? And what's the problem? Can you clarify it a little bit more?
thiru_ashok
Hi nathanx,
Thank you for your response.
5G configuration in PS-based example design for LDPC Encoder/Decoder IP V2.0 is not working as excepted. I always get the same values for Bit error and uncorrected bit error after decoder.
vkanchan
Hi @thiru_ashok ,
Did you enable the interactive GUI mode and run the design ? what is the range of SNR that is checked here ?
Thanks For Sharing
Lactose-Free Formula | (L-Zero)
