Matlab 7.6.0.221 (R2008a) Issue with System Generator 10.1.01.1182
Hello All
Xilinx System generator 10.1.01i is not supporting Matlab 7.6.0.221 (R2008a). Can any one help in making System generator 10.1.01.1182 to support with Matlab 2008a. Or else when would be the release of System generator 10.2i.
Attaching the error page.
Kailas Senan
Kailas,
MATLAB 2008a is not scheduled to be supported until service pack 2 for Sysgen 10.1 due out towards the end of June. For all version compatibility information you can reference AR 17966.
RJ Duran
Customer Application Engineer
Technical Support: http://www.xilinx.com/support
Xilinx User Community: http://forums.xilinx.com
Kailas,
RJ Duran
Hello Duran,
Thank you for your reply. I downloaded the service pack 2 of Sysgen 10.1 (10.1.02i) and now I am able to integrate with Matlab R2008a Simulink.
Kailas Senan
Anonymous
Not applicable
Hello Duran:
I have similar problem:
ISE webpack: 10.1, Service Pack 3 installed
ISE IP Update: IP update 3 installed
Matlab R2008a
When I launch DSP Generator it says unsupported version. I have re-booted my system for any possible stale values etc.
What am I doing wrong?
Please help. Thanks a lot in advance.
best regards,
ak
