sha2
RF SoC NCO freq hopping
Hi everybody
the subject is about the RFSoC RF converter IP
has someone perform any check about the NCO update dedicated ports ?
I am interested to know the following :
On page 137 of the spec joined here there is a figure that describe the NCO update via dedicated ports
1.    whats the max update rate on those ports ? Can we know whats the values T1 , T2 ?  if its depend in others parametters , so can you refer us to a more detailed spec ?
2.    when the ports are busy is the NCO previous configuration stable ?
3.    After a NCO update , how can we know to which NCO values the IP samples outputs  are related ? I mean , is there any indication (fixed latency , trig ports or whatever else  )
Sha2
klumsde
Hi @sha2
This feature is for managing frequency hopping.
It is expected that with this we can hop the frequency once every 1us.
T1 is there to illustrate the time from a request to the busy signal asserting. In this case there is the added condition that the logic will wait for the IP startup state machine before asserting busy / starting the writes.
T2 is variable and depends on the number of writes you are doing. In this case each register write takes 5x s_axi_aclk cycles.
During the update the previous Phase/Freq are still valid. The new values are applied when busy goes low.
 I am not sure what you mean in question 3. If you have a case where your tiles are aligned then you have the sysref mechanism to manage the update.
klumsde
Hi @sha2
GuyDorman
I am also interested in frequency hopping capability in my application.
Can you please let me know which application are you designing with the RFSoC which needs frequency hopping?
Thank you,
Guy
