olufola
Relaxing default timing constraints for HW Cosim
Hi Everyone,
I designed a pulse shaping circuit model using System Generator for DSP but it is not meeting one of the default timing constraints during HW Cosimulation. My design can tolerate a much relaxed timing constraint  and its not as tight as that imposed by default. I think the obvious solution is to edit the defualt constraint file after backing it up.
I could not locate the the default constraint file SysGen uses. I need to know where the default value for the failing constraint is specified for me to relax it. A screenshot of the the Sysgen hwcosim par report is attached.
chrisar
The constraints are set at in the clocking tab of the System Generator for DSP token.
Then anything that runs at a slower rate handeled with multi-cycle path constraints.
The constraint you slected though seems to be associate with a MMCM block.  These constraints are most likely generated by putting a constraint on the input of the MMCM block, and the tools then auto generateing the output constraints.
This is because the design is a HW-CoSim design.  When targeting HW-Cosim, you can't change the clock, as it is tied to a board, and is needed to make sure that the interface between the board and software is working correctly.  So you can not change it.
You could greate a custom JTAG HW-CoSim target that uses a differnt clock, even if it is for an existing board.
Chris
Versal ACAP: AI Engines | Embedded SW Support
olufola
Hi Chris,
You suggested that I should create a custom hwcosim target. Is there a primitive to do that or do I have to start from scratch?
Thank you.
