Strange result at the output of Negate block
Hello! I am doing a design with LUTs and I have dudes about a result I get from a negate block I have to use.
The design works properly, but I would like to know why happens this. If you see the picture, the input of the negate block is -999 but the output is -25, why it is not 999?
Thank you so much for your help.
Tags (3)
Professor
Professor
Re: Strange result at the output of Negate block
If you have a calculator that does hex numbers, you can see that 999 and -25 have
the same value in the lower 10 bits:
- 25 = 0xFFFFFFE7
999 = 0x000003E7
If the display you added is only 10 bits and signed, then it will report -25 rather
than 999.  You would need 11 bits to display the signed number properly.
-- Gabor
-- Gabor
As Gabor pointed out, it's probably a data type problem. If you can turn on the data type display (Simulink menu Format->Port/Signal Displays->Port Data Types), that will help determine if that is the case. I did a quick test and I got the expected result (see snapshot below):
Cheers,
Jim
Professor
Professor
You might also notice in Jim's diagram that the output of the negate block has one more bit
than its input.  In the originally posted diagram, you can't see the data widths, but there may
be some truncation when the negate block output goes into the multiplexer, whose other
inputs would have the same width as the input side of the negate block.  Since the display
is tapped off the bus connection between the negate block and the multiplexer, it's not clear
whether it gets the full output of the negate block or only those bits connected to the multiplexer.
-- Gabor
-- Gabor
So Is only a problem about the display format? So the functionality of my design is proper? I think so, because I get the number expectec at the output point of the cash block.
It's hard to say without knowing the data types at various points. If you can attach the model or a snopshot with all data type displayed on the model, we can take a look if it's just a display problem.
Cheers,
Jim
