sarahleony
Sysgen Mcode output error spreading code
Hi all,
I am trying to write code to an mcode block with this function:
function [z] = spreading(din)
persistent pr_sig, pr_sig = xl_state(zeros(1, 9),din);
pr_sig(1) = 1;
pr_sig(2) = 1;
pr_sig(3) = 0;
pr_sig(4) = 1;
pr_sig(5) = 1;
pr_sig(6) = 0;
pr_sig(7) = 0;
pr_sig(8) = 1;
persistent data1, data1 = xl_state(ones(1, 9),din);
persistent data2, data2 = xl_state(zeros(1, 9),din);
if din == 1
for i=1:8
data1(i) = xl_xor(data1(i),pr_sig(i));
z = data1(i);
end
else
for i=1:8
data2(i) = xl_xor(data2(i),pr_sig(i));
z = data2(i);
end
end
Essentially I want to take the input bit and my pseudo-random array (pr_sig) and bitwise XOR them together. Then I want to send the output out. This performs Direct sequence spreading. I know you can't output arrays, but I thought maybe this code would work. However I get this error:
output z is not assigned through all possible paths. A misspelling or a switch statement without otherwise statement may cause this error.
Anyone know what I am doing wrong?
Thank you for your time!!
meherp
You should have one return value for z.
Note that, in the below code, the value of 'z' is constant, but it is inside the loop, therefore code will generate the same error.
for i = 1:8
    z = 1;
end
There should be one return value at the end of execution e.g.
y = 0
for i = 1:8
    y = i;
end
z = y;
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
sarahleony
Thank you for the prompt response. Unfortunately that won't work for me because for every input (din) I would like to output 8 different bits (z(8)). I am trying to insert spread spectrum this way. Is there another way to do this? Based on the code edits I would only output 1 value...
