System Generator and DLL compatibility
does anybody has some experience with Simulink code genration when using the System Generator Toolbox? I Want to generate DLL files from the Simulink model to use it in another simulation enviroment. Is it still possible using bloicks from the System Generator Toolbox?
Kind regards,
Martin
Re: System Generator and DLL compatibility
@martin.leubner
System generator can not generate the DLL files. It only generates the HDL netlist and Hardware-cosimulation blocks to implement the design on the hardware.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
Yes I am aware of the fact, that the System Generator only generates HDL Code. But I can generate DLL files from a Simulink model, which could include a System Generator Block. So the question is still, can Simulink still generate the DLL files when a System Generator Block is present?
