System Generator crash at startup in Windows 10
I am using ISE 14.7 and Matlab 2013a in Windows 10 64-bit. I encountered the following problems:
1. When I run System Genrator, it opens Matlab and Simulink library OK, but 1 second after that, Matlab pop up error message and close. It happens every time, even after restarting the computer.
2. Then I try to open Matlab 2013a directly. Then navigate to Simulink library. I am able to open a few of my old designs. However, when I try to run it, it went through compiling, but right before simulation started, Matlab crash again. This also happens several times.
Anyone has a solution to this? Or any walkaround?
Thank you,
Fei
Re: System Generator crash at startup in Windows 10
check which version of ise 14,7 you have and what it supports
two versions, one works in windows 10, but only supports certain devices and functions
   other version, does not run in windows 10 ,   but does support all ..
did you find any solution for this issue?
Pedro
