There is only one line with a value of zero when I use co-simulation.
I have encountered some problems,when using the system generator for co-simulation, the output waveform of the JTAG module has only one line with a value of zero. The built system is normal in simulink.Pictures are as follows。Thank you very much.
Can you please share the ouput when you connect the "input port of Cosim block with output of Gateway-In port (rather than direct connection with input)".
It should work fine after above change.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
First of all, thanks for your answer. I have tried this method but there is only one output with zero.
Yesterday I tried a simple additon and the output was zero. It is wrong.
Can you please share the FPGA-board number.
I use the development board of zynq7020.
