akshay_iyngr95
Tutorial for filter using sysgen
I'm looking for a tutorial to design a bandpass filter using system generator.
Do any1 have a tutorial for this with new version of system generator and fir compiler.
Thanks and regards,
Akshay M
xud
tedbooth
For Xilinx docs and tutorials, the best place to look is in the Xilinx Documentation Navigator tool (DocNav).  Open the tool and select the "Design Hub View" at the upper left.  Select the "System Generator for DSP" option in the left column.  This will show all of the docs related to SysGen.  I don't see a tutorial that directly covers what you are looking for, but UG948 is probably a good place to start if you haven't seen it yet.
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
xud
akshay_iyngr95
Hi, @xud
Thank you
xud
@akshay_iyngr95
If you feel your question is answered, please close this thread by using accept solution.
Feel free to let me know if you have any good lab ideas for Sysgen tutorial, I can feedback this to Sysgen team.
