chenjianliang
'[USF-XSim-62] 'elaborate' step failed with error(s)' in system generator 2018.2 when simulating DDS module
OS: Windows 7
Vivado: 2018.2
Matlab: R2018a
Create a simple model with DDS_compiler_v6.0 as below:
Default parameter settings with the DDS block
and then click the simulate button. It works properly and finish successfully.
As I modify the model as below,
1. change the DDS block paramter , ‘Output Frequency' from 'fixed' to 'Programmable'
2. add another constant block and connect to the DDS 'config_tdata_pinc' with ufix_28_28 data type
Click the simulate button and the model report a error as below
ERROR: [USF-XSim-62] 'elaborate' step failed with error(s). Please check the Tcl console output or 'C:/Users/ChenJianliang/AppData/Local/Temp/xlsim5b9a6f73/hdl_netlist/xelab.sim/sim_1/behav/xsim/elaborate.log' file for more information. Please refer to 'C:/Users/CHENJI~1/AppData/Local/Temp/xlsim5b9a6f73/vivado.log' for more details.
the error message in the elaborate.log :
Starting static elaboration
ERROR: [VRFC 10-147] xbip_pipe_v3_0_5.xbip_pipe_v3_0_5_viv_comp failed to restore
ERROR: [VRFC 10-213] Registering Dependencies Error: The primary unit 'xbip_pipe_v3_0_5_viv_comp' could not be found during restore
ERROR: [VRFC 10-147] dds_compiler_v6_0_16.dds_compiler_v6_0_16_viv failed to restore
WARNING: [VRFC 10-122] dds_compiler_v6_0_16_viv remains a black-box since it has no binding entity [/wrk/2018.2/continuous/2018_06_14_2258646/packages/customer/vivado/data/ip/xilinx/dds_compiler_v6_0/hdl/dds_compiler_v6_0_vh_rfs.vhd:47411]
ERROR: [XSIM 43-3322] Static elaboration of top level Verilog design unit(s) in library work failed.
I tried to locate to the temp directory and run the tcl in command window but nothing changed.
I searched all the xsim-62 questions in the web but did not find a solution to this problem.
Even the model can not be simulated ,but it can be implemented the 'generate' process in the Xilinx Token.
Many thanks to everyone who can help.
chenjianliang
turn your windows update on and install all the system update packages, and reinstall the vivado
seems that's a system bug for windows 7
chenjianliang
seems not a easy case, is it?
chenjianliang
Should I wait for 2018.3...?
meherp
I tried the uploaded-design on my system. It is working fine for the "output frequency : programmable".
I attached the screenshot of the result.
Version which are used by me :
OS: Windows 10
Vivado: 2018.3
Matlab: R2018a
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
chenjianliang
Many thanks!
I will try the 2018.3 and check
chenjianliang
but... when will 2018.3 be released?
meherp
It is working fine on 2018.2 as well.
OS: Linux
Vivado: 2018.2
Matlab: R2018a
chenjianliang
well... I do not have a linux system to verify...
Do you think the problem comes from the difference between Vivado for Linux  and Vivado for Windows in 2018.2?
Or is there something incompatible in windows7 with vivado2018.2?
Current  cases:
win7 + 2018.2 (failed)
win10 + 2018.3 (fine)
linux + 2018.2 (fine)
wang_xiaoming
I meet the same problems as you,so did you have solved the problems? If solved,how?
chenjianliang
