Oxygen_Chu
Vitis cannot find "vck190" platform
UG1076 p193
But Vitis 2020.2 cannot find this "vck190" platform (Windows 10).
Is there any package should be installed in advance?
Tags (3)
florentw
Hi @Oxygen_Chu
Yes correct.
Florent
florentw
Hi @Oxygen_Chu
Refer to the note in the following page:
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/vitis_embedded_installation.html
The vck190 platform is an embedded acceleration platform so you will not be able to use it in Vitis running on a Windows OS
Also, when on a supported linux OS, the VCK190 platform is not part of the Vitis installation. It needs to be downloaded from the following page (or from github)
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-platforms.html
Florent
Oxygen_Chu
Hi, florentw~
I installed VCK190 on Windows 10 platform, and I see this in Vitis.
The acceleration cannot be done even if VCK190 correctly installed?
florentw
Hi @Oxygen_Chu
Yes correct.
Florent
