XAPP1161
Hello all,
I want to use vivado 16.3 for xapp 1161. While i tried to open using tcl file its showing version problem. What should i do? What changes should i make in tcl command to open it?
Thanks & Regards
Teacher drjohnsmith
Re: XAPP1161
Check, Xapps are written for one version of code, is your version the same as the Xapp ?
Re: XAPP1161
No, vivado 16.3 is later version. xapp is of older version.
Teacher drjohnsmith
Re: XAPP1161
well that be your problem then,
Voyager
Voyager
Re: XAPP1161
@vikaskanha,
The recommended way to migrate any Vivado project files from an older version to a newer version is:
1) Install both the older version of Vivado and the newer version of Vivado.
2) Build the project using the older version of Vivado.
3) Open the newly built project in the newer version of Vivado.  You will be prompted to let Vivado upgrade the project to that version.
4)If you no longer need the older version of Vivado, you can uninstall it.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
