01-20-2021 01:00 PM
After having updated Matlab 2020a to Update 6, when a I double-click on basic elements such register (or constant), I received a message error without being capable to set a value.
How to resolve this?
MATLAB Version: 9.8.0.1538580 (R2020a) Update 6
MATLAB License Number: 528812
Operating System: Microsoft Windows 10 Pro Version 10.0 (Build 18362)
Java Version: Java 1.8.0_202-b08 with Oracle Corporation Java HotSpot(TM) 64-Bit Server VM mixed mode
MATLAB Version 9.8 (R2020a)
Simulink Version 10.1 (R2020a)
>> xilinx.environment.getversion('sysgen')
ans =
'2020.1'
Best regards,
Richard
01-21-2021 09:09 AM
Even if with the Xilinx token / Xilinx System Generator block! Not able to open the GUI interface! Quite a worrying situation, could you help me on this?
02-11-2021 01:07 AM - edited 02-11-2021 01:14 AM
Are you getting any error as shown below after adding XSG block into canvas?
If so, can you please make sure you are invoking System generator tool and not Matlab/Simulink directly. I know its a basic thing and user in general don't do such things. But, just to rule out that is not the case from your end.
02-18-2021 09:50 AM
Absolutely not! The XSG environment is set correctly:
All you have to do to reproduce is to use Vivad0 2020.1/Matlab 2020a, create a Simulink blanl model, add the XSG block (or simple register block) and double-click on it.
02-19-2021 05:52 AM
Is the issue only after update6 installation ? was is working before this update with R2020a ? Would you please confirm ? This info will be helpful for us to debug further
Raju A.
02-22-2021 10:10 PM
Hi @opal-rt_fpga_grp ,
These steps have helped resolved the issue
