Visitor ritesh1889
Xilinx System Generator not configure matlab
Respected sir
when i open system generator to configured matlab then it shows error which is given in figure so i tried with different method i open system generator as a administrator then it configured but when i checked once it shows not configured...what i do?
Re: Xilinx System Generator not configure matlab
Install Matlab in a directory path without spaces and try reconfiguring using the Matlab configurator and then launching sysgen from the start menu in Administrator mode
Your current directory path has spaces in it(Program files).
Satish
Satish
Visitor ritesh1889
thanks it solved
