Zedboard in simulink and pmod port
Hi, I want to buy ZedBoard, because i have to use it in simulink environment (in ARM mode and FPGA mode) with AXI4. I need to comunicate outside with CAN (Controller Area Network). I found a Pmode CAN (https://store.digilentinc.com/pmod-can-can-2-0b-controller-with-integrated-transceiver/). It is linked with pmod port of zedboard and it use a SPI protocol to comunicate.
How i can devepoled it?
thanks
Are you using SysGen? If you are using only Matlab Simulink, I think you should consult with Mathworks.
I can use SysGen. I find these blocks:
https://reference.digilentinc.com/learn/programmable-logic/tutorials/pmod-ips/start
They are some blocks of pmod linked to zedboard (pmod can, pmod oled...), but they are in IP xilinx vivado.
Can i use the block of this link in simulink with SysGen, i.e. import as a block simulink?
news?
