Visitor sravan@243
cross correlation in xilinx
I WANT TO FIND THE DELAY BETWEEN TWO SIGNALS USING CROSS CORRELATION IN XILINX.CAN ANYONE EXPLAIN HOW CAN I PERFORM CROSS CORRELATION BETWEEN TWO SIGNALS IN XILINX
Sravan
Tags (2)
Teacher rcingham
Re: cross correlation in xilinx
The following thread may be helpful:
http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/cross-correlation-of-two-sine-signals-using-xilinx-blockset/td-p/120650
Designing a cross-correlator in HDL would be a difficult task, even for someone experienced in HDL-based FPGA design, unless they have done one before.
BTW, please don't shout.
"If it don't work in simulation, it won't work on the board."
Visitor sravan@243
Hi rcingham,
the thread you provided was very helpful in identifying the delay, thanks for that. Now i need to identify the multiple delays between two signals, for that i need to go for wigner distribution(i.e FFT of the auto correlation of the signal) of the signal.Could you please help me in identifying these multiple delays
Scholar joelby
These aren't FPGA-specific problems - have you modelled your system using a tool like Matlab? It is far quicker and easier to prototype and evaluate DSP algorithms in software tools. Once you've found a working solution, you can then implement it on your FPGA. In the meantime, a DSP-specific forum or an appropriate professor (if you're working at a university) might be more helpful.
