floating point IP logicore: accumulator
How to use floating point accumulator ip core
Re: floating point IP logicore: accumulator
hi @creationrgukt123 ,
Floating Point only generate the demo_tb testbench which you can add in your project which can help you to simulate the core. Example design for this core is not available so you can't generate it .
In the product there are some example on this core which can help you to create your own testbench .
https://www.xilinx.com/support/documentation/ip_documentation/floating_point/v7_0/pg060-floating-point.pdf
The demo testbench only available for VHDL user as product guide mentioned
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
sir actually i want to add an array of floating point values and store it in single register using floating point accumulator. But i am unable to understand some terms like t_last signal .
Hi @creationrgukt123
The Tlast signal, Tvalid and Tready signals are part of the AXI-Streaming protocol. Please refer to the UG761 and the references provided in it to understand more about the use of AXI-Stream protocol.
