how to increase the period of random binary?
Hi, To generate the random binary data in xilinx system generator I used LFSR block and it successed . However, I would like to increase the period of each binary  in data to about 14000 and I could not change the value of simulink system period (keep default =1). So how could we increase or widen the period of each binary output from LFSR? What is the best way to do that? I need to 14000 times. Thanks
You have to modify the “Explicit Sample Period” in the Advanced tab of the LFSR block.
I assume  the “simulink system period” you mention is the general one that appears in the System Generator token, isn’t it?
Good luck!
IKERLAN FPGA
fpga@ikerlan.es
