simulink system period
Hi all,
I have a design in System generator and going to implement it on the ZED board. I have run the timing analysis and the result says that there is no timing violation. I see an option 'Simulink system period(sec) ' set to 1(default) in clocking option of system generator icon(shown in figure below). My question is, what value should it be changed to ? what determines the simulink system period?
thank you in advance.
Re: simulink system period
HI @sai_shashi
Hope your query is addressed. As long as you are not designing the multi sample rate system. you can keep all the sample period values as '1' (in sysgen token and in Gateway in blocks)and work .
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
The timing analysis will be performed against the requirement set in the 'FPGA clock period.' The simulink system period is basically a normalization factor to make sample rate math easier in the simulink environment. It won't affect the timing analysis.
www.xilinx.com
thanks for your reply.
But will the simulink system period affect the hardware co-simulation timing. I mean by reducing the simulink system period will we be able to accelerate the design ? or what are the other parameters that the acceleration through hardware co-simulation depends upon ?
than you
check jtag frequency settings
Thanks and Regards
Balkrishan
where do i check jtag frequency settings ?
in generated hardware co simulation settings .
Thanks and Regards
Balkrishan
I have connected the zed board to PC through JTAG port.
In HWcosim settings editor window, the fields are inactive. whats is the reason?
HI @sai_shashi
Simulink system period  will not affect either HW cosimulation or the normal simulation speed. As Brian wiec, it is just a normalized value of the sample period value. and can be left at 1 if your entire simulink design works at one sample rate.
Only when your design involves multiple sample rates , the simulink sample period should be  the greatest common divisor of all the sample periods in the model.
Bharath
HI @sai_shashi
Bharath
