system generator error!
when i double click system generator in simulink ,it's display in follow:
--------------------------------- Version Log ----------------------------------
Version                                 Path
System Generator 10.1.3.1386            D:/Xilinx/10.1/DSP_Tools/common/bin/../../sysgen
AccelDSP 10.1.3.1386                    D:/Xilinx/10.1/DSP_Tools/AccelDSP
Matlab 7.6.0.324 (R2008a)               D:/MATLAB/R2008a
ISE 10.1.03i                            d:/Xilinx/10.1/ISE
Summary of Errors:
Error 0001: Undriven input port
     Block: 'xlsysgen_one_block_sim/Reg Out1'
Error 0001:
Reported by:
Details:
The input ports on this block must be driven by other Xilinx blocks
Please send snapshot of model.
Kappa.
hi
looks line u have an undriven input port..
maybe u haven't connected a gateway in block at input.
sandeep
the snapshot in the attachment!
it seems there is a problem with ur Mcode block, it  does not has input and output ports.
it must be a programe error
sandeep
this is not my mcode. this is mcode of system generator. when i double click the system gererator icon in the simulink library brower,then above error is show.
how to overcome this problem?
I am not able to rectify this error.
can you please help me  in this.
Anurag
Hi Raguna
u have connected only one input to AddSub block. The undrived input of this block is causing this error. If u do not reuire this block u should remove it.
cheers
sandeep
Thankyou for the quick reply.
Even after giving inputs, I am facing the same problem.
Raguna
hi
this time simulation failed as u have connected the o/p of mux to input of previous one.
do try to read the error message, it will give u a hint .
cheers
sandeep
Thankyou.
I could rectify this.
but the simulation is very fast that i can not figure out the results properly.
PS:PLease find attachment of the simulink file.
There is a feedback path in the model, try to add "assert" block into this model.
hi every one
i have problem with this block set
in its data sheet has been said that when "fwd_inv" not been driven its high
but when i dont drive it or even drive it with high or low logic in any condition it give error that its not driven
can anybody help me ?
model file has been attached
Is this the same issue seen in this thread, if so, please provide the error message you are seeing, if not, please start a new thread.
My previous message is for rafael1986
