rajeshkhanna
system generator gateway_in for jesd data issue
hi, i need to generate jesd data as input through gateway in block in system generator tool. we need to take 32 samples per clock. Each sample is 8 bit. matlab block provides options to take data as frames but xilinx blocks are not allowing. kindly help. Regards, Rajesh khanna
rkhatri
Hi @rajeshkhanna,
Yes gateway in block of system generator does not work on frame based if you want to process 32 samples per clock then this has to been done parallelly.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
rajeshkhanna
Hi, Thanks for your comments.
