SHik1300
system generator
I want to build for loop with one Mcode block and one Counter block . This loop has to seperate first 10 bits after counter=1 ,second 10 bits after counter = 2 and .... .
I have used xl_slice statement for this reason . The code is : ( x as input bits and i as counter)
function y = start11(x,i)
 y = xl_slice(x,(i*10)-1,(i-1)*10);
but i have this error in sytem generator simulink:Error("start11.m"): line 2:27 the 3rd argument must be a constant
Numbers produced by Conter block are not constant .
What i have to do to solve this ?
Thanks !
vkanchan
Hi @SHik1300 ,
The Xl_slice function uses the constant value such that its value is known to realize the function.
This is why I think it is hard to realize this function by using a variable as an argument.
One way to overcome this is to write a HDL code that slices bits of input bus and import it through HDL black box.
vkanchan
Hi @SHik1300 ,
