10-17-2018 02:14 AM
I am using an XFFT core in forward FFT mode, unscaled. According to the PG the expected output width is equal to input_width+ log2(transform length) +1. I have 16 bits input and a 256 length fft, so I expect 25 bits out.
However, in all my sims I have never seen that 25th bit used. My highest output is achieved when I put a full power DC signal in and this still only uses 24 bits. Have I made a mistake? If not, what conditions would exercise this bit?
As it stands my dB calculation has my highest possible power recorded at -6dB because of this...
10-24-2018 02:43 AM
Does the reply answer your question? If it answers, please give kudos or accept as solutions.
The maximum constant input is not the worst case input scenario for bit growth. You can have a look at "Finite Word Length Considerations" section on PG109.
10-17-2018 07:58 PM
have you tried with a different architecture?
10-18-2018 02:26 AM
@liy wrote:have you tried with a different architecture?
What do you mean? What aspect of the configuration do you suggest changing?
To be honest, I don't really want to have to try an assortment of different configurations to determine which one does what the PG says. Building thew IP and simulating takes a decent amount of time, this sounds like a surefire way to chew up an entire day. The PG is pretty clear that full bit growth leads to 25 bits of output. Do you know why this might not be the case?
10-22-2018 02:49 AM
you may need to use Matlab to verify if this is the Max
the output also related to the coefficient so the full DC may not be the worst case
10-24-2018 01:18 AM
@liy wrote:you may need to use Matlab to verify if this is the Max
Ok thanks. To be honest, we apply gain correction to account for real signal losses on the PCB so the 6dB offset won't be an issue in the long run, I was just interested into why this happened.
10-24-2018 02:43 AM
