rbriegel
Adding more Acceleration Kernels to dpu.xclbin
I have created the dpu.xclbin via the vitis flow successfully. In my Design, I would like to use other acceleration Kernels e.g. from Vitis Vision. How would I go about that? If I add other .xo files to the Vitis linker script that generates the dpu.xclbin, will the vitis_ai_dnndk framework still be able to find the dpu?
Robert
jasonwu
Hi @rbriegel ,
Yes, you can. I haven't seen any limitation for a combined use of DPU APIs and common OpenCL APIs.
Best Regards,
Jason
rbriegel
Thanks for the info Jason!
Do you know of any example code where this is down? E.g. accelerating pre/post processing in an opencl kernel?
Robert
jasonwu
HI @rbriegel ,
For Xilinx OpenCL sollutions RTL kernel and HLS kernel are more commonly used.
I am afraid that I haven't tried with any example yet. But you may find some OpenCV HLS kernel here:
https://github.com/Xilinx/Vitis_Libraries/tree/master/vision
Best Regards,
Jason
