qwqw0001
Can I use DNNDK for my model
hi
  I want use Alexnet, but Xilinx doesn't provide a demo.So,can I use DNNDK for my model? And if I want to use the VGG example provided by Xilinx, can I change its network,?For example, delete its full connection layer and not do padding.
  Any advice is helpful
 ylh
jasonwu
Hi @qwqw0001 ,
For deploying a Convent on FPGA using DNNDK the pb file(trained model) should be provided by end customer.
Then you can use DNNDK to compress and prune the model.
You can refer to DNNDK tutorial to get more details:
https://www.xilinx.com/support/documentation/sw_manuals/ai_inference/v1_6/ug1327-dnndk-user-guide.pdf
Best Regards,
Jason
jasonwu
Hi @qwqw0001 ,
In my opinion if you use DPU/DNNDK supported layers to construct Convnet it should be supported.
Here are 2 simple examples about how to train custom model and deploy it on MPSoC devices with DNNDK 3.1(Xilinx tools v2019.1):
https://github.com/gewuek/flower_classification_dnndk_v1
https://github.com/gewuek/flower_classification_dnndk_v2
Hope these can help.
Best Regards,
Jason
qwqw0001
hi @jasonwu ,
 Thanks for your reply. And I was also wondering if I could make changes to the VGG model provided by Xilinx, such as removing the full connection layer, after all, it is pruned and compressed by Xilinx, and pruning is not free for me.
  ylh
jasonwu
Hi @qwqw0001 ,
When you mentioned "VGG model provided by Xilinx" which one do you mean?
And BTW as I know most of the demo models we  provided are just pb files. If you want to modify the network you need to train the model by yourself. That means you need to do that from training to deployment all along.
Please feel free to comment if I have missed anything here.
Best Regards,
Jason
qwqw0001
hi @jasonwu ,
   Thanks for your reply. In the DPU documentation :" It includes a set of highly optimized instructions, and supports most convolutional neural networks, such as VGG,ResNet, GoogLeNet, YOLO, SSD, MobileNet, FPN,and others."
    As you said, if only pb files are provided, is the network structure of pb files compressed and pruned?
    ylh
jasonwu
Hi @qwqw0001 ,
Best Regards,
Jason
qwqw0001
I get it,thank you!
