longway2go
Can we have DPU with less bits? Since we have 3 kinds of 8-bit DPU
Hi all!
From this repo https://github.com/Xilinx/Vitis-AI/blob/master/doc/dpu_naming.md, It's supposed to have DPUs with different bit-width, but I only find 3 8bit DPU: DPUCADX8G / DPUCZDX8G / DPUCAHX8H. Do we have available less bits DPU? Like DPUCZDI4C in the repo. Or is there a way we can customize our own DPU?
Thanks!
jasonwu
Hi @longway2go ,
This is a good question. From the release note:
https://github.com/Xilinx/Vitis-AI/blob/master/doc/release-notes/1.x.md
you can see that the 4-bot demo is under EA.
That means it is not a full released version.
Let me try to find out if it is possible to get the IP and demo design.
Best Regards,
Jason
longway2go
Hi Jason,
I'm happy to try that, could you tell me where can I find that?
jasonwu
Hi @longway2go ,
Got some feedback from dev team. The tool chain is not ready.
So for now we can't provide custom design solution for 4-bit usage.
If you want the 4-bit demo as mentioned in the readme I would suggest you to contact Xilinx FAE.
Best Regards,
Jason
