chrischan
Critcal warnings from DPU XDC file
   Received critical warnings regarding DPU XDC file. Any suggestions? log file and XDC file attached
Chris
chrischan
can't attached XDC file, here is the screen capture.
chrischan
Critical warnings went away after I updated DPU IP to v2.0
gguasti
Hello
Please can you try to use the latest DPU release?
thanks
