jbond1007
[DNNDK] Invalid pixel value of input tensor
I have tensorflow model of Densenet. When I am running this on ZCU102, I get the following error:
[DNNDK] Invalid pixel value of input tensor: 19840
[DNNDK] Please check if decent tool produces correct quantization info.
I have checked the input image and the maximum pixel value in it was 221.
How could the DNNDK throw such error that the pixel value is 19840.
When I tried normalization by dividing with 255, it still says "Invalid pixel value: 128". When I print the Mat image all I could see are 1's and 0's.
Please Help!
jasonwu
Hi @jbond1007 ,
The input image pixel data need to be pre-processed before sending to DPU, you need to make sure that the pre-processing is just the same as when doing training, and also the input_scale value need to be multiplied to match the quantized network.
like code example here:
https://github.com/gewuek/flower_classification_dnndk_v2/blob/master/arm/flower_classification/src/main.cc
In this example the data is normalized in training, so it is done in ARM code.
Hope this can help.
Best Regards,
Jason
ss9701
Have you solved this problem? I also had this problem
ss9701
hello, I've done that, but it still prompts for errors.
[DNNDK] Invalid pixel value of input tensor: 5782
ss9701
My input_scale read from dnndk is 128, if I multiply 128 it will say: Invalid pixel value of input tensor: 5782.
But if I don't multiply the scale, it will say:  Invalid pixel value of input tensor: 128.
if I change the scale to 0.9999, it will become normal.
So I want to ask that if dnndk (vitis ai)  change the weight to +128 instead of +127 ?
This is my pre process:
