DNNDK examples on ZCU104
Hey everyone,
i managed to install the deephi dnndk tools on my ZCU104 board. The examples do run but it freezes the whole board at some time. Sometimes the whole example run throught without any problems but when starting another time the board freezes after a few seconds and i have to restart the board.
In the attached photo the board freezed right after starting the example video_analysis.
The ResNet50 worked fine, the face detection freezes after about ~10sec.
Maybe someone of you faced the same problem and know how to fix it.
ljl
The video examples require more power supply which can not be handled by ZCU104.
These examples work well in ZCU102 board.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
@qhall
It may resolve the issue.
Also, patch is not provided along with the document. Therefore it is recommended to not to use these patches direclty.
This just worked propertly! Thanks!
