hemilshah
DNNDK setup Host machine
I am trying to install DNNDK on Linux centos-08 PC and would like to know if it is possible or not?
Also, I have read this in the user guide, so can anyone help me with this (see attachment)
I need the installation package for the environment on which I am running (Linux Centos-08)
Best,
jasonwu
Hi @hemilshah ,
For DNNDK 3.1 here is a usedful Answer Record:
https://www.xilinx.com/support/answers/73058.html
For now VAI can't support Zynq-7000 in SW side. Because we don't have 32-bit compiled VAI associated libraries.
Best Regards,
Jason
jasonwu
Hi @hemilshah ,
As you can see on the DNNDK user guide the CentOS+DNNDK is not officially supported.
Although the CentOS is supported on VAI 1.2 for now the VAI/DNNDK is still a Ubuntu prefered tools.
So I would recommend you to choose supported version of Ubuntu if possible. That would save you sometime.
Best Regards,
Jason
hemilshah
Thank you for the previous reply @jasonwu
Can you please help me with setting up the evaluation board. In my case, I am using the ZedBoard.
I am not able to understand the connections to the ZedBoard. Also, I have downloaded the corresponding image file. Can you tell me what should I do next.
Best,
Hemil Shah
jasonwu
Hi @hemilshah ,
Best Regards,
Jason
hemilshah
Thanks, I was able to get started. Will let you know if I face any further difficulties.
Best,
