jorge_2015
DPU-TRD output files Vitis-AI
I have built Vitis-AI/DPU-TRD project and I can see the next files
Vitis-AI/DPU-TRD/prj/Vitis/binary_container_1/sd_card$ ls
BOOT.BIN  dpu.xclbin  image.ub  init.sh  platform_desc.txt  README.txt  zcu102_base.hwh
My question is if bitstream is embedded inside BOOT.BIN what is dpu.xclbin for?
Do I need to copy it to my sd_card?
I am seeing that xclbin is a container which packs FPGA bitstream for the DFX partition and host of related metadata like clock frequencies, information about instantiated compute units, etc.
Can I use xclbin instead of the .bit inside the BOOT.BIN for and embedded device? Or is this way of working more focused to Alveo boards?
jheaton
BOOT.bin contains the bitstream for the platform. The platform does not contain any acceleration kernels, including the dpu. Think of this as the "static" part of the design. It nevers changes.
All acceleration kernels (.xclbins),  get loaded into the PL at runtime by XRT. This includes the dpu.xclbin.
jorge_2015
Hi @jheaton ,
Thank you for your answer, about what you told me a question has come to my mind:
How does it know the XRT in runtime which acceleration kernel must use? Just copying it from sd card to /usr/lib and exporting paths like in setup.sh it's enough?
Or you have to put a reference to the xclbin in a meta.json file like in alveo examples for an embedded device?
BR
jheaton
For general Vitis accleration kernels, your host sw would load the kernel (xclbin). There are examples of how to do this in the Vitis documentation.
The dpu xclbin is  a special case, the Vitis AI libraries call xrt under the hood and load the xlcbin for you. In this case you just need to copy the xclbin to the target file system and it will get loaded for you.Capture.PNG
hrexha
Hello @jheaton,
Regarding the matter, I had one question. Is it possible to build the BOOT.BIN file form petalinux with platform .bit file included and then use it with dpu.xclbin I get from Vitis flow. I had problems when loading the xclbin for executing Vitis-AI library samples. There is some time-out or something. So I  use the BOOT.BIN file I get from vitis flow, which I would not like to. Do you have any idea why?
hokim
xclbin consists of a hw bitstream and meta data for xrt
The bitstream in xclbin is actually not used in zynq(mp) platform(which doesn't use partial reconfiguration for hw) .
So you can change  hw by modifying the bitstream in boot.bin
But you should be careful to change hw because meta data has hw information and its inconsistency with actual hw might cause problem.
Check log after dpu project build
link.steps.log
step: running xclbinutil
timestamp: 27 Jun 2020 15:32:32
cmd: xclbinutil --add-section BITSTREAM:RAW:/home/hokim/work/vitis_ai/dpu_prj/binary_container_1/link/int/system.bit --force --key-value SYS:mode:flat --add-section :JSON:/home/hokim/work/vitis_ai/dpu_prj/binary_container_1/link/int/dpu.rtd --add-section CLOCK_FREQ_TOPOLOGY:JSON:/home/hokim/work/vitis_ai/dpu_prj/binary_container_1/link/int/dpu_xml.rtd --add-section BUILD_METADATA:JSON:/home/hokim/work/vitis_ai/dpu_prj/binary_container_1/link/int/dpu_build.rtd --add-section EMBEDDED_METADATA:RAW:/home/hokim/work/vitis_ai/dpu_prj/binary_container_1/link/int/dpu.xml --add-section SYSTEM_METADATA:RAW:/home/hokim/work/vitis_ai/dpu_prj/binary_container_1/link/int/systemDiagramModelSlrBaseAddress.json --key-value SYS:PlatformVBNV:em.avnet.com_ultra96v2_ultra96v2_base_1_0 --output /home/hokim/work/vitis_ai/dpu_prj/binary_container_1/link/int/dpu.xclbin
dpu.rtd and dpu.xml are used for xrt
hw modification should be based on dpu_prj/binary_container_1/link/vivado/vpl/prj/prj.xpr
