Decent-cpu running error
when I run decent-cpu on my ubuntu pc, it reports:
decent-cpu: error while loading shared libraries: libopencv_highgui.so.2.4: cannot open shared object file: No such file or directory
does decent-cpu only support opencv2.4?
Re: Decent-cpu running error
@phoenixmy
There are some OpenCV functions which are not backward compatible.  Precisely how that may impact DNNDK I am not certain.  Are you certain that you are not already running 2.4? You can double-check to see if the files are installed:
sudo locate libopencv_core.so.2.4
Also, you can confirm which version you have installed:
dpkg -l | grep libopencv
You could potentially setup an Anaconda virtual environment, specifically for DNNDK.  I would actually recommend doing this as you can then have multiple environments for different versions of TF, DNNDK, etc.
Sudo ld_config may also help, depending on the exact nature of your situation:
https://github.com/pjreddie/darknet/issues/382
--Quenton
@phoenixmy
--Quenton
@quentonh  已写:
@phoenixmy
There are some OpenCV functions which are not backward compatible.  Precisely how that may impact Are you certain that you are not already running 2.4.  You can double-check to see if the files are installed:
--Quenton
@quentonh
Thanks for your reply.
The issue is fixed when I install opencv 2.4.9.
But when I run yolo2caffe example(https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/Darknet-Caffe-Conversion) and excute "bash 2_quantize.sh", 'decent-cpu' crash, below is the log("log.txt"), do you know the root cause for it?
@phoenixmy  已写:
@quentonh  已写:
@phoenixmy
--Quenton
@quentonh
New update:
problem solved, it my mistake, I used the wrong v3.prototext file(the one for 80 classes), but acutally, my own has only 10 classes.
so the filters value in layer81 is 45, not 255.
