ELF file generation using .prototxt and. caffe model and error during make file
I am using zedboard (digilent:xc7z020) for DPU TRD
i follw these steps to generate dpu_resnet50_0.elf
first i run: decent-cpu quantize..........prototxt .....  and  .caffemodel
this invoke a folder consisting deploy prototxt and caffemodel
then i run a sh file consisting
model_dir='quantize_results'
output_dir='dnnc'
dnnc-dpu1.4.0.1 --prototxt=${model_dir}/deploy.prototxt \
--caffemodel=${model_dir}/deploy.caffemodel \
--output_dir=${output_dir} \
--net_name="resnet50" \
--dpu="800FA" \
--mode="debug" \
--cpu_arch="arm64"
which results in a .elf file in my directory as given below
/home/sahoo/ZED_chek_oct18/DNNDK/dnnc/dpu_resnet50_0.elf
when i use this for generation of image file by running make command to build the image  then i got follwing error
"/home/sahoo/ZED_chek_oct18/image_creation_resnet50/resnet50/model/dpu_resnet50_0.elf: file not recognized: File format not recognized
collect2: error: ld returned 1 exit status
Makefile:75: recipe for target 'resnet50' failed
make: *** [resnet50] Error 1"
Re: ELF file generation using .prototxt and. caffe model and error during make file
Try changing the dnnc --cpu_arch option from arm64 to arm32.
