Ethernet issues with the ZCU104
Description in ug1327-dnndk-user-guide:
The ubuntu screenshot via UART is shown below:
Questions:
1.Why can't I find the IPv4 for this board?(It will appear for a few seconds and then disappear)
2.Why does this board always link up and link down?
Tags (4)
Re: Ethernet issues with the ZCU104
Are you trying it with a local ethernet connection?
AR#66553 may provide some hints.
Thank you for your answer.
If I connect the host machine(GBE) directly, it works. But if I use a 10/100M switch, the problems remain. I hope it can be fixed in the next release.
