Exact Configuration of DPU in ZCU104 Petalinux
can anyone guide me towards the Information with which features exactly the DPU IP was configured in the Petalinux build for the ZCU104?
Using
dexplorer -w
I can't access all the infos I'm looking for, eg is High DSP turned on? How many Ultra RAM Blocks are beeing used etc.
Thanks in advance
Cheers
Use the dexplorer command to obtain the following information:
Example:(DExplorer version 2.0,DNNDK v3.0)
[DPU IP Spec]
IP Timestamp : 2019-09-13 20:30:00
DPU Core Count : 1
[DPU Core Configuration List]
DPU Core : #0
DPU Enabled : Yes
DPU Arch : B2304
DPU Target Version : v1.4.0
DPU Freqency : 300 MHz
Ram Usage : Low
DepthwiseConv : Enabled
DepthwiseConv+Relu6 : Enabled
Conv+Leakyrelu : Enabled
Channel Augmentation : Enabled
Average Pool : Enabled
Other information can only be confirmed on PG338 or on Summary Tab of DPU Configuration in IP customization.
Refer to  Figure 14: Summary Tab of DPU Configuration on PG338.
I found all of the above already, sorry if that was not clear through my inital post. What I'm looking for is how exactly the IP in the ZCU104 Petalinux design was configured. I believe  what is shown in Figure 14 in PG338 are not necessarly the settings used for the ZCU104 build?
Maybe some Xilinx FAE might know this? @quentonh do you have any info on this by chance?
Thanks in advance!
