How to convert YOLOv3-tiny darknet to caffemodel
I tried darknet2caffemodel conversion tutorial (https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/Darknet-Caffe-Conversion).
I have converted default/example YOLOv3 darknet model to caffemodel, and it is successfully running on ZCU102 board.
The tutorial page mention that YOLOv3/tiny darknet is able to convert to caffemodel.
> The conversion from Darknet to Caffe supports YOLOv2/tiny, YOLOv2, YOLOv3/tiny, and YOLOv3 basic networks.
Next step, I try to convert YOLOv3-tiny darknet model which is downloaded from https://pjreddie.com/darknet/yolo/.
but when I convert yolov3-tiny.cfg and yolov3-tiny.weights, error reported as follows:
$ bash -v 0_convert.sh
#!/bin/bash
python ../yolo_convert.py \
0_model_darknet/yolov3-tiny.cfg \
0_model_darknet/yolov3-tiny.weights \
1_model_caffe/v3.prototxt \
1_model_caffe/v3.caffemodel
I0604 12:06:15.485395 4005 layer_factory.hpp:77] Creating layer layer20-concat
I0604 12:06:15.485421 4005 net.cpp:84] Creating Layer layer20-concat
I0604 12:06:15.485446 4005 net.cpp:406] layer20-concat <- layer19-upsample
I0604 12:06:15.485471 4005 net.cpp:406] layer20-concat <- layer8-conv_layer8-act_0_split_1
I0604 12:06:15.485497 4005 net.cpp:380] layer20-concat -> layer20-concat
F0604 12:06:15.485532 4005 concat_layer.cpp:42] Check failed: top_shape[j] == bottom[i]->shape(j) (24 vs. 26) All inputs must have the same shape, except at concat_axis.
*** Check failure stack trace: ***
0_convert.sh: line 7: 4005 Aborted (core dumped) python ../yolo_convert.py 0_model_darknet/yolov3-tiny.cfg 0_model_darknet/yolov3-tiny.weights 1_model_caffe/v3.prototxt 1_model_caffe/v3.caffemodel
Is there any way to solve this problem?
BRs
Re: How to convert YOLOv3-tiny darknet to caffemodel
Thanks reply.
I have solved YOLOv3-tiny darknet conversion problem and the converted YOLOv3-tiny is running on ZCU102 board (80class, 28fps).
That layer20 upsample was not problem bacause Deephi has prepared DeephiResize for upsamle layer.
This mismatch 24 vs 26 error is caused in layer11-maxpool.
This is a critical issue of deephi darknet2caffe conversion program code.
I modified it and then I could convert YOLOv3-tiny model.
BRs
I would suspect your up_sample layer is not converted correctly. Are you upsampling using deconvolution. If you could include the prototxt for that layer, it might be something easy to spot.
Thanks reply.
BRs
Have you meet the "caffe.LayerParameter" has no field named "upsample_param" problem, and How sloved it?
can you share me your caffemodel and prototxt?
I have not met "upsample_param" problem.
Have you tried darknet2caffe conversion tutorial ?
I seem your yolov3-caffemodel is not generated by Deephi darknet2caffe conversion tool.
@yokota06y
Hi, I'm also trying to convert the tiny yolo weights to caffe using the Xilinx tutorial but I get the same error.
Can you tell me how to fix it?
Hi, I'm trying to convert the YOLOv3 darknet weights to caffemodel using the "darknet2caffe.py" code.
Unfortunately, I Could get the prototxt file but not  the caffemodel file that is similar to weights.
Thanks a lot.
回复: How to convert YOLOv3-tiny darknet to caffemodel
@yokota06y
I meet the same problem.
F0713 21:48:05.792819 9621 concat_layer.cpp:42] Check failed: top_shape[j] == bottom[i]->shape(j) (24 vs. 26) All inputs must have the same shape, except at concat_axis.
Can you send your yolo_convert.py to me?Email:1845959584@qq.com,Thanks!
@yokota06y
I meet the same problem.concat_layer.cpp:42] Check failed: top_shape[j] == bottom[i]->shape(j) (24 vs. 26)
Email:aaaa942124@126.com
Thanks!
@yokota06y
I meet the same problem. bottom[i]->shape(j) (24 vs. 26)
Can you tell me how to fix the issue of deephi darknet2caffe conversion program code?
or share your yolo_convert.py with me?
Email:272132922@qq.com
Thanks!
1.  find concat_layer.cpp in the caffe-master folder .
2. Go to line 42 (in my case) and comment the equality check
//CHECK_EQ(top_shape[j], bottom[i]-> shape(j))
// <<"All inputs must have the same shape , except at concat axis.";
3. Go to line 49 (in my case) and comment the equality check
//CHECK_EQ(bottom_count_sum, top[0]->count());
Run make clean for caffe-master.
Build caffe again
make pycaffe
make all
and finally run
0_bash_convert.sh
you will able convert the Yolo-tinyv3 to caffe successfully.
We also have published complete tutorial [with demo output] on "YoloV3 Tiny Darknet to Caffe with DNNDK and Ultra96 FPGA". If anyone interested then here is the complete tutorial link: YoloV3-tiny Darknet to Caffe with Ultra96.
krishna@logictronix.com
Thank you for good information.
(1) In my environment, layer11 with maxpooling size=1 causes performance degradation.
However your tutorial page output picture is no performance degration.
Is it correct ? In my case, I have
re-trained yolov3-tiny with maxpool size=1.
(2) In your tutorial, I  seem anchor box  is not change from yolov3 to yolov3-tiny (main.cc or utils.h).
Is it ok ?
Now I don't have pc and confirm it.
Sorry, if there were some mistakes
I success to run yolov3-tiny under ZCU102.The new version yolo_convert.py and the cfg file is below. The reason maybe is the oringe darknet's maxpool is not compatible with the caffe's maxpool. It makes concat run mistake. To solve it, I add ''pad=1" in yolov3-tiny.cfg(about 84 line),and rewrite part of yolo_convert.py(about 411 line ,oringe is: "if block.has_key('pad') and int(block['pad']) == 1: pooling_param['pad'] = str((int(block['size'])-1)/2)" ,now is "if block.has_key('pad'): pooling_param['pad'] = '1' " ). The model trained by the oringe yolov3-tiny ,can be converted to the DNNDK success, and run perfectly. enjoy it! 1845959584@qq.com
The cfg file is below.
Thanks for your solution, it solved my problem!
Thanks for your workaround. Can you also explain why the you modify that line? So that I can also apply this to other networks. There are many other maxpool layers and they dont need to be padded?
My assumption is that layer8 is 26 in width and layer19 is 24, so we have to pad layer9 to widen all subsequent layers upto layer19. At the end layer8 and layer19 will have the same width and can be processed in layer20(the concat layer). Is that right?
There is a mismatch between Caffe and Darknet for max pool layers with stride of one. This creates a blob mismatch in Caffe and will cause an error.
The other max pooling layers are not effected, since their stride is not one.
The easiet solition is to just comment the layer in the .cfg file and retrain:
hello ,i tried to convert my own yolov3-tiny model,after i fixed the maxpool problem i tried to test the caffe model using the 1_test_caffe.sh. the result is very confused. it seemed that the banding box are not right. there will be several BB on one target ,but none of that can occupy the whole target. seemed like the no maxmium supress function dose not working correctlly. do i need to modify anywhere else? TKS!
hello,I have the same problem,Have you found a solution to the problem?Can you share with me?
thanks!
