Multiple ML models on multiple DPU cores
Hi everyone,
Is Xilinx DPU able to run multiple ML models on multiple DPU cores (2 separated models on 2 DPU cores, one model on 1 DPU core) concurrently?
Thank you.
Re: Multiple ML models on multiple DPU cores
Hello @nvl1109
You can see the Multi-Task demo : Segmentation + Detection.
UG1354 - Vitis AI Library User Guide (v1.0)
Thank you
Yoichi
Thank you @katsuki for the great info. This document looks like first release from 2019.2. My project currently using 2019.1 Xilinx tools. So is it possible to run similar demo on 2019.1? Thank you.
@nvl1109
Unfortunately that 2019.2 is required to use Vitis AI.
If you want to try it, we recommend using the sample.
Thank you
Yoichi
Thank you. So, the answer could be not possible on 2019.1 Xilinx tools. But on Vitis AI (2019.2), it is possible. ??
