UG1354 Demo Errors
Hello.
I am trying to do demos and sample projects which are instructed in Vitis AI Library User Guide(UG1354 (v1.0)). I have downloaded all github files it says. But in installation part i am having errors. It is usually "libraries are not found" errors when i try to build .sh files. The pictures of errors are attached. What are we missing? Isn't tutorial sheet not covered enough?  Are there other prerequisites that not mentioned in document?WhatsApp Image 2020-02-14 at 17.50.06.jpegWhatsApp Image 2020-02-14 at 17.43.59.jpeg
Re: UG1354 Demo Errors
You are in the wrong docker conatiner. Use the run time docker container to build the sw applications:
./docker_run.sh xilinx/vitis-ai:runtime-1.0.0-cpu
