kanojojo
ZCU102-AI-img link 404 in ug1354
The system image for ZCU102 mentioned in "ug1354: Vitis AI Library User Guide"(v1.2) July 7, 2020
-- CH2 -- Setting Up the Target -- Step1
is 404 hyperlinked.
Can someone help on this?
Best Regards.
gguasti
you are right, thanks for highlighting this.
there is a missing ".gz"
please use this link:
https://www.xilinx.com/bin/public/openDownload?filename=xilinx-zcu102-dpu-v2020.1-v1.2.0.img.gz
gguasti
reyk
When I download this file on WIndows 10 and uncompress it with Winzip and attempt to mount it Windows says "Couldn't mount file, the disc image file is corrupted.
Is there an md5 sum for the .img file or the compressed .gz file?
