wangzishou
build Vitis AI envirmention for zynq7000
Hi, I learned from other posts that Vitis AI supports zynq7000, So I tried to compile the Vitis AI environment.
Hi, 我从其他帖子上了解到Vitis AI已经支持zynq7000 系列,所以我尝试着去构建Vitis AI运行环境。
but I follow https://github.com/gewuek/vitis_ai_custom_platform_flowhttps://www.xilinx.com/html_docs/vitis_ai/1_2/gjp1592545687662.html and other processes At times, I always encounter the problem that packagegroup-petalinux-vitisai cannot be installed.
但是我按照https://github.com/gewuek/vitis_ai_custom_platform_flow  / https://www.xilinx.com/html_docs/vitis_ai/1_2/gjp1592545687662.html 以及其他流程操作时,总会碰到无法安装packagegroup-petalinux-vitisai 的问题。
I want to get a definite answer to this question, and whether xilinx has successfully deployed Vitis AI on the zynq7000 board.
我也非常想知道这个问题的答案,同时Xilinx 官方人员是否在zynq7000系列的开发板上成功部署过Vitis AI.
Looking forward to getting a reply from Xilinx technical support, thanks
期待得到Xilinx技术支持的回复,谢谢。
graces
目前不支持,提供的Vitis AI runtime package是基于aarch64编译的。DPU是支持Zynq7000器件,可回退DNNDK。
之前有个类似的讨论帖供参考:
https://forums.xilinx.com/t5/AI-and-Vitis-AI/Vitis-AI-for-Zynq7000-family-devices/m-p/1100570#M3915
