louisli
failed to install decent
I am working under the user guide of the DNNDK.
I can see that DNNC is installed successfully.
$ dnnc --version
dnnc version v2.04
DPU Target : v1.4.0
Build Label: Apr 24 2019 19:12:00
Copyright @2019 Xilinx Inc. All Rights Reserved.
However, there is a problem when I tried to install the Deep Compression Tool (DECENT). The command and error can be seen below.
$ decent --version
decent: error while loading shared libraries: libcudart.so.9.0: cannot open shared object file: No such file or directory
Can you please help me check this issue? Thank you!
regards,
Louis
lvalena
Searching with "ubuntu install cuda" will provide many hits, one of which may be:
Install NVIDIA CUDA 9.0 on Ubuntu 16.04.4 LTS
lvalena
The message "error while loading shared libraries: libcudart.so.9.0" indicates that a CUDA library is missing. Please see UG1327 (v1.4) p. 8:
You may try using your favorite search engine to look for instructions on how to install CUDA and cuDNN using the keywords "install cudnn".
louisli
Thanks for your detailed reply!
I have thought about this possibility. However, it seems that I have already installed the required packages. Below is the command and information when I was trying to install DECENT and DNNC.
$ sudo ./install.sh ZCU102
Inspect system environment ...
[system version]
16.04
[CUDA version]
9.0
[CUDNN version]
7.0.5
Begin to install Xilinx DNNDK tools on host ...
Complete dnnc installation successfully.
Complete CPU version of decent for caffe installation successfully.
Complete GPU version of decent installation successfully.
I have used the following commands to check the CUDA and cuDNN version. Any idea on what is the problem?
$ cat /usr/local/cuda/version.txt
CUDA Version 9.0.176
$ cat /usr/local/cuda/include/cudnn.h | grep CUDNN_MAJOR -A 2
#define CUDNN_MAJOR 7
#define CUDNN_MINOR 0
#define CUDNN_PATCHLEVEL 5
#define CUDNN_VERSION (CUDNN_MAJOR * 1000 + CUDNN_MINOR * 100 + CUDNN_PATCHLEVEL)
#include "driver_types.h"
lvalena
tongtyr
Have you solved this problem?
I met the same problem,too.
