BruceChen
ultra96v2 always reboots when execute any examples of Avnet-COMMON-Vitis-AI-1-1-2020-05-15.zip
I installed a pre-build SD image, http://avnet.me/avnet-ultra96v2-vitis-ai-1.1-image, to my ultra96v2, and also deployed http://avnet.me/Avnet-COMMON-Vitis-AI-1-1-image. But ultra96v2 always reboots once I execute the examples from that vitis ai 1.1 above. For example,
$ cd Vitis-AI-Library/overview/samples/facedetect
$ ./test_video_facedetect densebox_640_360 0
Note I also tried other examples. Should this release work for ultra96v2 by default? Or do I need to configure my ultra96v2 somehow? Or recompile DPU with different configuration in some cases?
jasonwu
Hi @BruceChen ,
Since this is a release image from AVNET, did they provide the step by step flow to run the test?
Best Regards,
Jason
BruceChen
bhfletcher
Voyager
Voyager
If you didn't update the PMICs on your Ultra96-V2, then you could be running into the issue described here:
https://www.element14.com/community/message/276288/l/ultra96-v2-errata#276288
You can learn more about this, including how to request a procedure to update your Ultra96-V2 PMICs here:
https://www.element14.com/community/groups/power-management/blog/2020/01/23/infineon-pmic-updates-to-avnet-products
https://www.element14.com/community/events/5588/l/pmbus-and-power-supply-telemetry
Bryan
BruceChen
Yeah. You're right. I just found this as well. Thank you!
